I have a powermaster 140 amp one-wire alternator, with a 4 gauge lead running right to the battery. The other day, the volts were fine at idle. but when i went to pull out, they went up to about 16 v at under 2k rpm. so i turned everything on (headlights, wipers, a/c, electric cooling fan) to keep the voltage down until i got home. volts went down to about 12.7. by the time i got home, it would overcharge with everything still on. i let it sit for 30 minutes and started it back up and it was fine...so i replaced the 4 ga charge lead since it looked like the insulation was receding from the terminals. oh, and when it was hot it was kind of limp feeling.
so, is this a regulator problem inside the alternator, or is it just a badly made cable?
