PRErequisites for CAMS?
  • Thread starter Thread starter dvtr-
  • Start date Start date Apr 11, 2010
dvtr-
44
Houston, TX
Apr 11, 2010
  • Apr 11, 2010
Im currently working on an 01 gt auto with 40k miles im thinking about putting alotta power in the motor without a blower so i was thinking cams what should i think about before going out and buying. Which ones should i buy and is that the best way to add alotta power without a blower?
ErikTheBeast
124
Kansas City MO
Apr 12, 2010
  • Apr 12, 2010
Hitech stage II hands down. Then throw in some longtubes and 4.10's. A full bolt on GT w/ hitechs should make around 300rwhp.
scupking
1,186
Enfield, CT
Apr 12, 2010
  • Apr 12, 2010
+1 that's what I did. Also my numbers of 293rwhp are on a mustang dyno. If I put her on a dynojet I would be around 310 rwhp.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Apr 13, 2010
  • Apr 13, 2010
whats your definition of alot of power?
fobnicat
87
Georgia
Apr 13, 2010
  • Apr 13, 2010
What will you be doing with the car? Just driving? Dragging? Twisties?
C
CatmanJJ
Captain Tangnet
20+ Year Stangneter
Feb 5, 2002
4,379
Maryland
Apr 13, 2010
  • Apr 13, 2010
What about Trickflow heads and a set of cams? What kind of power are people with this setup putting down? I thought they had a matching intake manifold as well.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Apr 13, 2010
  • Apr 13, 2010
for the price of trick flow heads and cams and all the other little crap you could get a used vortech kit, and make lot more power..
N8Dogg98
3,872
238
184
MN
Apr 13, 2010
  • Apr 13, 2010
I'm also curious what kind of power one could make with the TF heads, cams, and TF intake manifold.
dvtr-
44
Houston, TX
Apr 13, 2010
  • Apr 13, 2010
thanks for the input guys, basically what im trying to do is get alot of performance out of my car without a blower, whats the best route for me to take?
M
Midnight2V
224
Oklahoma
Apr 13, 2010
#10
  • Apr 13, 2010
  • #10
dvtr-, are you wanting to do a built shortblock? The best way to make a lot of power NA is with a lot of RPM, which a shortblock will allow for. If you don't want a built shortblock and a blower is off the table, how about nitrous? Anything up to about a 125 shot is relatively safe.
As far as which cam you select, you really need to match it to the set of heads you go with. A set of cams that gives great results on a stock set of heads is not necessarily the right profile for a ported set of heads or a set of trick flows. Your ideal LSA, duration and ICL will change dramatically depending on the flow capability of your heads, so do your research and choose wisely. Know this, cams give dramatically better performance on ported heads compared to unported heads.
Also, springs go hand in hand with performance cams, I cannot stress enough the need for high performance springs. Just because a cam doesn't need an aftermarket spring, doesn't mean you shouldn't get one. Keeping a stock spring on an aftermarket cam can be disastrous, you are changing the net lift and the lift rate the spring must undergo after who knows how many cycles in the stock profile. This is a huge shockload and is certainly the most common cause of stock spring failure on aftermarket cams. One thing most people don't know about valve springs is that they can actually contribute power, especially power after the peak by eliminating valve float.
As far as bolt-ons, the only things that make any significant power are full length headers, intake manifold or plenum, and exhaust mid-pipe.
CAI, Throttlebody, MAF, and mufflers really make no SIGNIFICANT power at anything near stock levels and will gain you nothing but a lighter wallet except (MAYBE) at all out extreme NA. Anyone telling you differently is selling something. The stock equipment really is that good despite the reputation it sometimes gets saddled with.
Technically gears make no power, but they are undeniably the BEST performance bang for the buck you can put on your car. People will say this ratio is best, or that one is best, you need to do your own research and figure out according to your mods, and a dynograph which sets of gears are best for you. Generally it will be between 3.73 and 4.30 but may be something else.
Hopefully this will put you on the right track. If you need any other assistance, just post up.
2006KJ
128
North West PA
Apr 13, 2010
#11
  • Apr 13, 2010
  • #11
^^^ great info.. thank you.
C
CatmanJJ
Captain Tangnet
20+ Year Stangneter
Feb 5, 2002
4,379
Maryland
Apr 15, 2010
#12
  • Apr 15, 2010
  • #12
Well that's true but he specifically said he didn't want to go the blower route.
Plus I was just wondering what kinda of numbers one can get, I think I've seen other cammed GTs around the 300 rwhp mark, just wonder how much that would increase with the new heads since they've been out for a while. Nobody said it was cheap but I can argue with the idea of a N/A power since I have cams in my Mach.
W
wrecked2001
10
#13
  • Apr 15, 2010
  • #13
I just got my TF top end kit in, I substituted it with the 38cc track heat heads so I can run boost at a later time. I am throwing this on top of a Livernois 4.6 eco shortblock, stock compression. I didn't want to go FI yet because of the difficulty of getting dyno tunes in the UK. I going to run the TF/SCT X3 tuner to tune it. When i get it together hopefully I can find a dyno and get some numbers.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
