I finished my AOD to T5 swap at about 9 pm Monday night. Hurray! Then I started my car and heard this clanking noise. Something in the rotating mass was definately touching something it should not. Damn! I figured maybe the starter teeth were touching the flywheel and needed a shim. I had to leave it till Tuesday. I only had an hour to work on it so I Tuesday so I pulled the starter. No damage on the teeth. Crap! Today I took off work a little early and pulled the tranny back out. It turns out that the clutch pressure plate is touching the bellhousing. I "modified" the bellhousing hoping that it wouldn't touch anymore, but damnit it stll does. It's not a clank, but a scrape now. I don't want to pull the tranny again and I don't know what else I can do to give the bellhousing more clearance. So I'm seriously considering starting the car and letting it run till the noise is gone.
Has anyone had this happen? It's a King Cobra clutch and pressure plate and a stock Borg and Warner T5 and stock bellhousing.
