Priming question???
  • Thread starter Thread starter DMAN302
  • Start date Start date Apr 14, 2005
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 14, 2005
  • Apr 14, 2005
Will turning the key to start position with the coil wire and fuel pump relay removed allow me to prime the oil system? Will the engine build oil pressure by this method? Will my gauge (aftermarket) register pressure by this method??
Thanks, Derek.
TT91
1,536
Paramus, NJ
Apr 14, 2005
  • Apr 14, 2005
no, the motor needs to physically turn over in order for the pump to make pressure. Or you can prime the pump by hand.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Apr 14, 2005
  • Apr 14, 2005
Ok will priming by hand fill the oil filter?..I have changed the oil, but due to time constraints I was not able to start the car again(done last week)...I don't like the idea of a cold start without having filter issue taken care of.
TT91
1,536
Paramus, NJ
Apr 14, 2005
  • Apr 14, 2005
Whats the situation?When was the motor last run? Is the filter filled?
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Apr 14, 2005
  • Apr 14, 2005
Motor was started for first time this this year last week. After a short trip I pulled her into the garage and did a full oil change at that time...I did not fill the filter though. Due to time crunch I could not at that time start her up and had to move on to other projects (wife related). Now 1 week later I am looking to fire her up, but don't like the idea of having a cold start AND having the oil filter have to fill at the same time. I'm worried the time it takes the system to fill the filter and get up to pressure, that the period of oil starvation may hurt the bearings..though I may be wrong.
TT91
1,536
Paramus, NJ
Apr 14, 2005
  • Apr 14, 2005
So, remove the filter and fill it up. As long as this isnt the first time running, a cold start is not going to effect it. As soon as the crank is moving the oil pickup is going to suck up all that oil in the sump and spew it all over the internals. No need to worry. Fill the filter, it wont leak, and screw it back on. Give it hell!
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Apr 14, 2005
  • Apr 14, 2005
A1, thanks for your time.
TT91
1,536
Paramus, NJ
Apr 14, 2005
  • Apr 14, 2005
Your welcome D, let me know how it goes. My motor will be sitting for a year by the time I turn it over, so priming with the pump will be needed. Good luck
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
  • brandyn200
  • Jun 20, 2026
AeroCoupe
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
