pro-m negative wedge kit
The Kit is great. It is straight forward to install. The hardest part of the install is getting the old upper ball joint off if that is any clue. The kit will not drop your car 1.5 inches. Any upper arm re-location will not give you that much body drop. You will probably see about 3/4 of an inch in body drop with the Kit. If you want more, you will have to do something with the springs. I went with the Pro-Motorsport springs. I think the height is just right on the car with 1 inch lowering blocks on the rear. Here is a picture:
