probably a stupid question
95Mustang302
302
Ok, i have a 95 mustang thats getting the trickflow h/c/i, and a fox tb conversion in the process. I want to try and keep the egr system hooked up for now, but I need to know where the stock fox egr hooks up to get the exhaust gasses from, and where I can get the tube. I know on the 95 it got the gasses from the passenger side header.
If anyone can help that would be great...
Derek
Regulate the flow of exhaust gases into the incoming air. At WOT, no exhaust gases are recirculated. I'm not sure what tube you are asking about, on Fox bodies the exhaust gas is routed through the intake manifold. I am sure of that now. I can't remember off the top of my head what the egr valve gets hooked up to, but you might try searching the tech forum.
lol, why isn't anybody else helping? I'm rebuilding my engine right now, so I can't look at it and I don't have my reference book with me. Hopefully another member can help you with this issue. Good luck Derek!
Post it, and they will come.
If you are using a different (than the fox stock unit) intake manifold then you can route the egr using what was originally the air pump holes in the back side of the heads. There are a couple of 302 equipped vehicles that used these for egr from the factory, so the pipes can be found in a j/y.
If you are still using the stock cats, removing the functionality of the air pump may promote plugging of the cats. If using aftermarket cats or non at all, then the air passages can be used for egr without serious consequence.
I am pretty sure I have a faq on my site about the egr, and consequences of removing it. I would just post it, but I can't access my site from work.
Good Luck and congrats on the decision to keep the egr
jason
The EGR serves one main function and a secondary beneficial consequence: main is to reduce NOx emissions by lowering combustion temperatures(because exhaust gases cannot burn). This also tends to lower the risk of part-throttle pinging.
On a Fox, the EGR passages are all inside the instake manifold. They get routed through the center of the lower intake to the underside of the upper intake and then into the EGR spacer that is between the TB and upper intake. The valve hangs off the back of the spacer and controls exhaust recirculation from there.
You probably need a Fox upper intake and maybe even an aftermarket SN95 TB elbow if you want to keep the EGR. I'm not sure, though. I've never played with post-'93 cars.
