problem & engine pics
Suspect
256
GA.
threw on the elbow/tb so i could measure for my cai..ran into a problem. sensor hits on the vc's and the elbow hits it in the back. either some kinda spacer or go ahead and do a swap to a fox style tb. :shrug:
and heres some better ones. 2 things i dont like. the overflow bottle.. maybe paint it black or just get a new one. and the upper rad hose. i might swap it out for a black one. whatcha think?
thxs!
i already have a 1in spacer just so the intake can clear the vc's. im prolly just going to read up on the fox tb swap. good thing is i hear accufab makes a 90mm tb. bad thing is it sets me back cuz ill have to look for more parts. :(
If you dont wanna do a Fox swap...remove the elbow at the upper and try putting 1/2" nuts over your studs, sorta like a spacer..slap the TB on and see if it moves the problem out enuf to clear your issues... Then you could get a 1/2" or more EGR spacer and use it...
this ones a UPR 1/2" EGR delete spacer.. They do make thicker ones.
wow, it's coming together nicely, Tony!
I'd see about ditching the elbow and using the TB you already have -- you'd probably either just need a fox throttle cable or maybe you could modify your stocker (loop it to shorten it?) to get it to work.
thxs rio! i was reading an old thread on fox tb swaps and you had the same pic in the thread. so i thought that could work. i might get the swap parts anyway and do it later down the road.
thxs paul! im pretty happy with the way its going. took a lil bit, but im not trying to rush.
I would try grinding as well. I had to grind my elbow a little. I ground the EGR area as well as the flange that the t-body bolts to to get better access to the plug that is right there.
You should have plenty of room to grind things down.
even if you do the fox swap you need a 1 inch intake spacer... I have those valve covers, i wish i never bought them... i cant take them off with my supercharger in the car... sucks... you need all new intake hardware after the 1 inch spacer as well.
u could do one of three things.
1. grind down the egr on the elbow and just thread the hole and plug it
2. do a fox tb swap
3. if its worth it to ya and dont wanna spend the money on a new tb, i modified my intake manifold to put the 94-95 tb on without the elbow. you will have to drill new holes in the manifold and make a plate to cover the egr opening on the manifold. and make a bracket for the throttle cable and it should work. i had the same issue on my car when i put the fox valve covers on. i couldnt get the tb off without taking the upper plenum off. it wasnt too difficult. i just used some 1/8 inch thick aluminum to make the brackets
Fox body vc's work great on our cars :nice:
You just gotta take out some of the baffle and get a bit creative
with the oil fill tube :)
Some have cut the tube in half and rewelded for a more
suitable position
I went for the easy solution with a 3" section of radiator hose
with a slight bend that was from some sort of little ricer car :shrug:
anyway
The Fox vc's offer more room yet keep a very low profile ;)
They worked great with my stud mount Scorpion rr's :D
I didn't need any kind of spacer with my combo :shrug:
Grady
