  • 1994 - 1995 Specific Tech
Problem hooking up Autometer gauge
  • Thread starter Thread starter 95riosnake
  • Start date Start date Dec 23, 2005
95riosnake
630
Pittsburgh, PA
Dec 23, 2005
  • Dec 23, 2005
little question. I bought an Autometer Phantom A/F gauge on eBay last week and installed it last night (I know this gauge does little, nothing more than a light show really, but I thought it was cool and I got it for a decent price). The problem is, I fired the car up and the gauge is not working right. Instead of scanning from left to right and back again about twice a second, it goes REALLY slow like one sweep every 3 seconds. Then pegs to "lean" whenever the throttle is even barely pushed. My question is, WTF is the problem? I hooked it up exactly as the directions from the box, autometer's site, and various how-to's say to (signal wire needs to be spliced into the wire in pin 44 on the ECU which is a gray wire with a light blue stripe). I have gone over everything a dozen times already. I HIGHLY doubt the gauge is defective, because it was new, still sealed in the box, not even any dust on it. The only thing I can think is that the signal wire was not long enough to go from the driver's side a-pillar to the passenger side kick panel (to the ECU), so I used remote wire (small blue wire used to turn on amplifiers for car stereos when the ignition is turned on) to lengthen the wire. Could this have too much resistance or be distorting the signal in some way? I guess it could be a bad O2 sensor, but my car runs fine, so I don't think it's that. Anybody care to share how they hooked up their A/F gauge, specifically how they lengthened the wire, or any other tips?
95cobraguy
637
11
Concord, NC by way of LI, NY
Dec 24, 2005
  • Dec 24, 2005
i spliced into the same wire by the computer, u can go somewhere and have them hook up a scan tool so u can see what type of signal the computer is getting from the sensor and see if they match.
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Dec 24, 2005
  • Dec 24, 2005
If you have time and want to confirm your gauge is screwed up, then hook it up to the other o2 sensor wire. It's pin 43 I think and the wire is R/BK.
95riosnake
630
Pittsburgh, PA
Dec 26, 2005
  • Dec 26, 2005
hooked it up to the left O2 and got the same thing, I guess the gauge might be f'ed up. That's just great cuz there is no warranty on a gauge you buy from an individual.
Stangfreak95
add a 4
3,571
Dec 26, 2005
  • Dec 26, 2005
Oh sorry to hear that man. I'm assuming the gauge is screwed up. I dont think your "remote wire" is too small. If I remember correctly the wires from that gauge are pretty thin from the start. Are you sure your GROUND is good ? Just recheck your ignition and ground wire's connections.
But I'm sure you already did this..Good luck.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Autometer 3318 Fuel Gauge
  • cbac89
  • Apr 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2025
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
J
Shift light
  • Jfriedrich
  • Jun 22, 2025
SN95 4.6L Mustang Tech Dec 29, 2025
dirk shorter
D
