Problem Installing Alpine Head Unit
Ok so I have come to a point of utter frustration with this car yet again.
I bought an Alpine head unit a few weeks ago, and put it in the mustang this past week. I ordered the correct mach-friendly wiring harness with the radio from crutchfield. I wired everything up correctly, then turned it on. Only the passenger side rear speaker had sound, along with my subwoofer. I checked, rechecked, cussed, rechecked, etc... I then hooked up a book shelf speaker to each individual lead coming out of the head unit itself to verify that it was outputting signal to every channel and it was. I then called crutchfield support and we came to the conclusion that the problem was the wiring harness adapter (it has a gain box to adjust the output and not have bad results with the factory amps). So they sent me a new harness.
I put the harness in yesterday, I now have sound coming only from the driver side front speaker (the one by the mirror), and the sub. I have run out of ideas as to what the hell is wrong, I've checked EVERY connection time and time again. All speakers worked perfectly before I pulled the factory head units. I hope someone can give me some advice cuz I am fed up.
Thanks in advance everyone.
If I remember right theres a blue and pink or some stupid color on the adapter harness that isnt hooked to anything. That hooks to the blue amp switching wire on the Alpine to turn on the factory amps. Take it fwiw, this may not be your problem, but it was mine.
T
Okay, I read it this time, and I am stumped. I bought the kenwood I have and called crutchfield for the harness as well. Plugged everything in and it work perfect. If I remember correct, (if you have the 460 mach), doesn't crutch field actually give two adaptors. One being for speakers and power and such and the other was some device for the amps. Does this sound familar.
Yes there are two adapters. One for power, illumination, etc... and the other for the speakers. They both tie into one plug to go into the back of the head unit. I really am stumped, I will take a look tomorrow for the "not used" wire. I hope something didn't fry in the factory amps or something, cuz i was not wanting to get into alot of expense for this. I was just tired of having a cd player that never worked and having my sub rigged up using a line level input box for the amp signal.
Well I looked at the "unused" wires, there are two. One is orange with a white stripe, the other orange with a black stripe. I tried hooking them up to the remote wire, nothing changed. I really don't know wtf is going on with this thing. I'm about to take it to an audio shop and have them frustrate themselves with it, I've had enough.
You don't want your amp turn on hooked to your orange with anything wires.. THose are for illumination and dimmer..:nono:
Crutchfield techs generally don't know **** about what you need, because they aren't installers, they just read the computer like a cashier at walmart.
I do have a sheet giving detailed instructions on the Mach Install, but, it is unfortuanately at my shop, 500 miles from me..
I use Stinger/Aamp/BestKits products for all my installs... You can call their customer tech line and they will be very helpful to you..
The number is 1-800-477-2267...
If you can take a picture of your harness, I may be able to help you.
I had to splice two wires to the amp lead. I believe there was blue and orange, and a black with white. Its been a couple months though, so I could be off on the colors, but I took mine up to best buy and they told me I had to wire up a amp turn on to make the factory amps work. Once I did what they said, mine has worked great.
These aren't the illumination wires. I have the illumination wire hooked up correctly. The solid orange wire was the illumination/dimmer. These other two wires are not accounted for in the wiring schematic that came with the harness. I'll take a picture tomorrow
Here are a couple pics of the harness.
The whole harness:
Closeup of the part of the harness in question. This shows the two unused wires, the orange wire with the black stripe is somehow used from what I can see as there is a blade in the factory harness to connect to the adapter harness, the orange/white one does not line up to a blade in the factory harness. The only problem is I can't figure out what this orange/black wire is or what it needs to be hooked to.
I used to have a complicated adapter like that with my Mach 460, but I found a cheap one from Metra that's designed for the Mach 460. It's model number 70-5514. I use that exact one with a Pioneer in my Mach 460 without problems.
Of course, this sends the amplified audio from the head unit to the amps, so I wouldn't crank the volume too high. The fancy adapter from Crutchfield will simply help keep you from shooting yourself in the foot and cranking the volume too high.
Careful you get the 70-5514, not the 70-5519. The 70-5519 is for the 99-04's, and won't work with the 94-98. I made that mistake.
