Problem Installing Timing Set
Hoytster
I don't dare do that to my Knob
Dec 30, 2002
1,069
700
164
Cornwall, PA
Had a problem installing my timing set today. This was the set that came with my TFS H/C/I kit (dynaroll set). When I opened the set I noticed it has two allen head screws (instructions said to countersink the thrust plate bolt holes and use these screws so they fit below the surface of the plate) and a bronze washer, both which were not on the stock timing set. Confused, I called Trick Flow the next day and they said they had never heard of having to countersink the thrust plate, which made sense since the bronze washer was not hitting the stock bolts on the thrust plate (the reason for countersinking and using the allen head screws). But they made it sound like I still needed to use the bronze washer.
Anyways, I went to put the timing set on today, with the bronze washer, and after torquing the cam sprocket bolt I could not turn the engine over! So I removed the cam sprocket bolt and pulled the set back off. It appeared the bronze washer was too thick and was being squashed between the timing set and the thrust plate. So I took the bronze washer off and installed the timing set without it and the engine turns over just fine. I pulled on the cam sprocket to see if I had any play and I have a VERY slight amount of play (about .004), which should be fine.
I'm just not very confident that I put everything together right, especially since there was nothing in the instructions that said you shouldn't use the bronze washer for certain applications. The only thing I know is I can't use the washer that came with the set because it is just a little to thick and will hold the engine back from turning.
Here are some pics to make what I'm talking about a little clearer (maybe).
Here's the bronze washer included with the set:
Here's the stock timing set with some explanations:
Damn, that's exactly why I want to get this right before I fire this engine up.
Thankfully I dry fitted everything before I put the timing set on and DIDN'T countersink the thrust plate because I saw I didn't need to do it.
I have a feeling the instructions in the kit are just wrong, and I have everything put together correctly without the bronze bearing. With the bronze bearing I have absolutely NO PLAY but without the bearing I have a good .003-.004.
I know when I did the cam in my 5.0 explorer I didn't have any bushings to use, but that was a different timing set also.
Well god dang. Listin to this. So last saturday I get my timming chain in the mail from Summit. As you know Chris I had the two allen head bolts, and the bronze washer. I had no instructions so I wanted to make sure what the heck those bolts were for. Thats when I came on here and heard that I wasnt the only one. So tonite "tuesday" I go out and install my timming chain. I dry fit everything and double check it all. I had about .001-.002 of cam play. Everything looks good and cam spins over by hand. Rap everything up for the night and check my emails. low and behold I get an email on this. Now Im double guessing myself. After seeing those pics and spending all this money, that doesnt make me happy. I have installed many cams before. Never second guessed myself, now I am. Why does it work on mine just fine but not yours. Am I doing something wrong, are you, are the parts wrong. Its the same freaking cam, block, and thrust plate. lol, I feel safer spending an extra $60 and getting a new timming set. What do we do?
Well I called Trick Flow again today and described my problem. The guy talked to a couple other people and basically came back and told me the way I have it installed should be correct. He stated as long as I'm getting the correct endplay then I should be fine. He also said dynaroll was incorrect in telling people to countersink their thrust plate and to NEVER do this.
Wish I would be more confident in that way I have it installed...
