Ok it's a brake problem. here I go.. you tell me what's wrong. I know some possibilities.. but i'm not sure.
First off i have a 01 2v 4.6 with a saleen supercharger bolted on top. I am using a 4v (cobra) power steering pump. It has the little connector on the pump that I never used. I have 4 wheel abs with traction control (the car didn't have abs when i got it). The brakes have all been primed as well as the power steering. (if you haven't noticed this is a 4.6 swap). Well the power steering works fine on it after I got it primed and I figured the brakes would too after. Well I guess I primed my hydro boost because I did what the service manual told me to do. Well the fuse block wiring harness is a cobra also... which I do not think matters. Well when I am running the car and press the brakes the brakes go all the way down... not dead but it feels as if your moving your foot through water if you know what I mean... there is a little resistance there. I get very slight brake power. Anyone know what the problem is? The service manual lists using a NEXT GENERATINO STAR (NGS) TESTER AND A NGS FLASH CABLE to plug in under the dash and follow the instructions. I do not know what that does... but I assume it's necessary because the manual says "necessary equipment" under brake bleeding. Does anyone know where i can get someone to do that for me? without paying ford $ 1,921.91 to look at my car?
Also the technique I used for priming my brakes were first the master cylinder then each caliper in the correct order. I first opened the bleeder valve, had someone depress the brake pedal, then i tighten the bleeder valve, then released the brake.. and repeated until I thought the air was gone because the bubbles disappeared.
Possible problems....
1.) can't use cobra power steering pump
2.) brakes need to be re-bled (is that a word)
3.) hydraullic control unit (abs booster) needs to be replaced
4.) cobra fuse block is no good
5.) ?
Please help me out...
5.) ?
