  • Mustang Sound & Shine All
Problem with aftermarket HU
  • Thread starter Thread starter 98V6 K.I.T.T.
  • Start date Start date Jun 19, 2008
98V6 K.I.T.T.
2,049
Everett, Washington
Jun 19, 2008
  • Jun 19, 2008
Just thought I would see what you guys thought. I installed an older Pioneer CD player in my friends car (probably a good 10 years or older HU). Well, hooked it up and everything played well worked fine. Well, my friend calls and tells me that it just stopped working so I come take a look at it and it's definately not turning on. Well, for one I found out that they tried to pull the deck out themselves and the antenna wire attached to the deck cut through so I have to re do that, but that shouldn't cause the stereo not to work. So I look at the harness thinking that maybe either the ground or power wire came loose. Nope appears fine, next I check the fuse on the player and the fuse that goes to the radio in the car and they aren't blown. I'm going to re do the wires and see if that helps, but it seems like the stereo is just dead is there anything else I should check or try? Unfortunately I don't have another stereo around to test to see if that one would work. Any help would be nice.
mixedbreed02gt
Banned
Oct 6, 2007
Nashville, TN
Jun 19, 2008
  • Jun 19, 2008
it's KIA....scrap it and replace it.
08blueskunk
217
Maine
Jun 20, 2008
  • Jun 20, 2008
many times the antenna supplies ground to the deck if it is unhooked it may not work. some cars can be tempermental about things like that. and especialy a mustang.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jun 20, 2008
  • Jun 20, 2008
Why was the radio pulled by friend? Sounds like they were messing with it or around the area and killed it. Time to upgrade.
98V6 K.I.T.T.
2,049
Everett, Washington
Jun 21, 2008
  • Jun 21, 2008
Well it was put into an older Chevy Astro van, I had this deck laying around doing nothing and my friend needed some tunes. I'm not sure why they were messing with it, I'm guessing it wasn't working so they decided to see if they could see why maybe.....I need to pick up a new cage for the deck so you could play with it. When I pulled it out myself it came out pretty easily but I found the antenna wire got cut off.
Z
ZakeriD
112
  • Jun 25, 2008
the antenna should never supply the ground...
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
  • brandyn200
  • Jun 20, 2026
AeroCoupe
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
G
Help! Radio, door chime fuse keeps blowing.
  • goofyfoot53
  • Sep 9, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Sep 9, 2025
91AOD5.0LX
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
T
