Ok im only 20yrs old so I know im not the best. Having problems with my car banging out on a normal driving with the timing at 10-12 degrees and fuel pressure at 38psi. I have it set at that because im trieng to make a nitrous pass.
When i have the timing at 18 degrees and fuel pressure at 38psi it runs fine on motor.
Car consits of 331 stroker , 185cnc heads , holley sytemax intake, 75 mm throttle body, anderson power pipe, 90mm mass air calibrated for 42lbs injectors. msd coil, brand new 255lb intank pump, t-rex pump, 1 3/4 long tube headers , x pipe.
All parts and sensors are brand new, seriously everything is new. I even replaced the computer, computer harness, injector harness, o2 harness.
Please give me any info or opinions.
Thx, David.
Thx, David.
