I installed SN95 Cobra brakes on my 86 Mustang GT. Other than not having installed the moan brackets (which I don't have yet) it is a complete setup from Ford Motorsport 5 lug axles to the correct cobra brake pads. Unfortunately I've been having an issue with the inner brake pads rubbing the rotor when I go around corners. You can hear them scrapping. In an effort to determine the cause I removed the calipers and rotors and checked everything over. I have 2 suspisions as to the cause:
1) I don't have the moan brackets. Could this be the cause?
2) I pulled on the axles and discovered that both have a small amount of play. You can pull them out approx 1/16" more or less (I didn't actually measure it). It is obvious that they have been moving while I drive as there is a clean portion on the axle where it has been scraping on the axle seal. Should there be play in the axles? Was I sent the wrong axles?
