Why do you guys insist on "measuring" fuel economy based on the gauge reading. There is no way that the stock gauge is accurate enough to do this. It is common knowledge that oil pressure and coolant temps on the stock cluster are far from accurate; so why is it always assumed that the fuel level gauge is accurate and calibrated?
I have been keeping a very simple excel sheet since I built my 408w. It is very easy to do. Keep the receipt when you fill up. Enter the miles traveled, gallons added, and let the spreadsheet do its thing. If you don't have excel then use a calculator.
Doing this will allow you to quatify the effects of things like fuel additives.
The first half of my tank will get me about 50 miles, and the second half will get me around 150 miles. My gauge is the extreme of uncalibrated, but I think you can get my point.
Sorry if this sounds like a rant, but this seems just as ridiculous to me as using a wobbly on a torque wrench.
I agree with Hissin (as always), in that you need to pull the codes. You may have a bad ect or something. Let the computer do some of the work for you.
jason
