problem with gas mileage..
PeteyAce
346
I had no o2 sensors so i was getting around 150mi to the tank, and i finally got the sensors put them in and filled my tank. and im still getting the same ****ty mileage. what the hell? when i installed them,the connections were dirty but i gave em' a wipe down and plugged them in one went right in the other had a little trouble but i got it in has far and best i can...why the crapp ass mileage?
What is the MPG that you get? My buddy was getting 100 miles to a tank, but that was due to his leaking fuel tank grommet (get my point?).
There are a ton of things that can cause the milage. Has the car had a full tune-up recently? How far does your foot get into it? Does it idle a lot?
More info will help. Pull the codes too.
Good luck.
Just as an FYI - Over the winter I acumulated 50 miles on a half of a tank of gas. So if I crunch the numbers, I got 6.5MPG when I was running my car on nicer days or moving it in and out of the garage. In the summer I get almost 300 miles to a tank but I spend a bit of time on the highway so I can get into and out of the city.
i got an 1989 lx, simple 5.0 all i got is exhaust and 3.73
the car hasnt had a tune up ever since i brought it 2 years this july. i got around 140mi to the tank now. which is the same amount i got before the sensors.
Part of that 6.5mpg was startup, warmup, and probably cold, low speed driving. I never got below 19.5mpg in my '89 GT 5-spd. Best was a hair over 24 and that was my normal commute, not even 50% highway.
Why do you guys insist on "measuring" fuel economy based on the gauge reading. There is no way that the stock gauge is accurate enough to do this. It is common knowledge that oil pressure and coolant temps on the stock cluster are far from accurate; so why is it always assumed that the fuel level gauge is accurate and calibrated?
I have been keeping a very simple excel sheet since I built my 408w. It is very easy to do. Keep the receipt when you fill up. Enter the miles traveled, gallons added, and let the spreadsheet do its thing. If you don't have excel then use a calculator.
Doing this will allow you to quatify the effects of things like fuel additives.
The first half of my tank will get me about 50 miles, and the second half will get me around 150 miles. My gauge is the extreme of uncalibrated, but I think you can get my point.
Sorry if this sounds like a rant, but this seems just as ridiculous to me as using a wobbly on a torque wrench.
I agree with Hissin (as always), in that you need to pull the codes. You may have a bad ect or something. Let the computer do some of the work for you.
jason
Yeah, I know why I used so much gas and got almost no mileage from the car. I ran it a few times up to operating temperature to test things I installed over winter + I drove it when the weather was warm and no salt was on the roads.
I was just using my experience to try and demonstrate the range of MPG that can be had from these cars.
Try changing the basics (plugs/wires/etc.) and see if that does anything. That is if the codes don't reveal any issues.
Thats good because it also supports the fact that mileage can be affected by LOTS of factors. I imagine the winter gasoline in the north is a bit different from the summer formulation also. It is here, but it only varies by about as much as the weather in L.A., which is ~60* in the winter and 85 in the summer(in other words, not much). In my neck of the woods, it goes from 40-110 seasonally.
