You posted a TECH question in Talk. This limits your chances of getting some really good advice, since most guys aren't looking for Tech stuff in the Talk forum. You may want to PM thr moderators (85ragtop, Killercanary, Mustang5L5, Celeb, FrankenStang, FastDriver) and get them to move you post. You'll get more tech help that way.
having said that, here's some answers to your questions...
See the
"Surging Idle Checklist for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The
first two posts contain all the updates to the fixes. At last count there were
24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
Power window problems
Motor removal & replacement
Remove the door mounted speaker & the upholstery panel to gain access to the motor. There are 3 screws (5/16" hex head, I think) that secure the motor in place. Remove them and the motor comes out without any problems. Once you remove all the screws from the motor, and it falls away from the gear teeth on the arm for the glass, the glass will move up and down. You may need a helper to hold the glass once the motor screws are out, since the gear on the motor holds the glass from sliding up or down
Motor interchange
The motor is the same for left side or right side, only the gearboxes are different. If you can't find the complete assembly for the side you want, you can get either side and use the old gearbox on the new motor.
Cheap and easy fix for common problem
The window motor gearbox has 3 plastic rollers that are a safety clutch to prevent possible injury if the window is rolled up while something or someone is hanging out the window. The plastic rollers will often disintegrate into chunks of plastic and the window will no longer roll up or down. The motor runs, but the window does not move or only move a lttle.
The Help! section of your local auto parts store will have the replacement plastic rollers.
See NAPA
Window Regulator Gear Plug
Napa p/n BalKamp 6651524
Cost is 9.49$
AutoZone and other auto parts stores see Dorman 74410 / Window Lift Motor Gear Kit
Cost is $7.99
Power Window Wiring Diagrams
Diagrams courtesy of Tmoss & Stang&2birds
87-92 model cars power window wiring:
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 model cars power window wiring:
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring
Mustang FAQ - Wiring & Engine Info Everyone should bookmark
