  • SN95 4.6L Mustang Tech
problem with running right
  • Thread starter Thread starter ktpguy
  • Start date Start date Feb 17, 2004
K
ktpguy
shepherdsville ky
Feb 17, 2004
  • Feb 17, 2004
i just installed bbk long tube headers, bbk off road x-pipe, and slp load mouth exhaust on a 2001 gt. now the car does want to run right. it cuts out under hard accelration for some reason. it didnt do it before the install. i was wandering if anyone else has had any problem or has an ideal what it could be
StangYellow
1,052
Feb 17, 2004
  • Feb 17, 2004
The only thing I can think of is that since you are running an off road X pipe, your O2 sensors are telling your computer that the fuel mixture is too rich. Which will lead to the computer adapting to this and lowering your air/fuel mixture. The computer will alter the mixture, but i dont think that the car would "cut out". Thats too extreme.
Did you make sure the O2 sensors are in there tightly? If they are loose, that might mess with the computer also, possibly causing your car to run poorly.
K
ktpguy
shepherdsville ky
Mar 5, 2004
  • Mar 5, 2004
yea i went back and checked everything. everything was thight. it acts like the tracking control is kicking in so i turned it off and its still does it. i guess i'm going to scan for any codes next
E
el_kid_1
738
Puerto Rico
Mar 5, 2004
  • Mar 5, 2004
Scan the ECC and get back in here. Anyways, sounds like you are having problems with the O2 sensors. Is your SES light on?
K
ktpguy
shepherdsville ky
Mar 16, 2004
  • Mar 16, 2004
i scanned it and the mil eliminators wasnt working so i replaced them. the ses light stayed off for two days then came back on agian yesterday. so i'm going to scan it agian today to see what it says. is there something that could be messing up the mils. ses light is on but its running fine. the o2 are working just fine. how i knew the first set of mils wasnt working was the rear o2 sensors were plusing at the same rate as the fronts after i replaced the mils it was back to normal agian. so i'm lost as to why the ses light came on agian but i should know why by this evening. thanks for the tips and info
Xanax
103
  • Mar 16, 2004
I agree it would be smart to replace your 02 sensors!
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 16, 2004
  • Mar 16, 2004
does it cut out just when its cold or even after its warmed up , the rear O2s will kick the light but really wont affect the running of it , sounds to me like your factory calibration just isnt taking well to the exhaust changes . Might need to send your ECM to Tim for adjustment
K
ktpguy
shepherdsville ky
Mar 17, 2004
  • Mar 17, 2004
well thats what i was going to do was get a chip for it. the codes coming up are emission code. the front and rear o2 senors are plusing the same. the volts are 8.99 to 0 on the fronts and 6 to 0 on the rears. i think its a tuning problem. there are no local shops here in louisville but theres pauls performance in cincy so i guess i'll give them a call to see what they say thank agian
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 12:38 PM
AlexM556
A
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
