Engine will start fine and run okay but if I give it some gas, it will sort of sputter. There's a misfire in there but I'm not sure if it's the coil or a sensor of some sort that could cause the problem? Normally I'd just change the coil, the plugs are stock Ford replacement and have about 2000 miles on them. The wires are Ford Racing but they are old and the coil wire is God-knows-what but that wouldn't be enough to cause this problem.
I do have IAC problems from time to time but I doubt that could cause the spark to drop.
