Problem with spark
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Engine will start fine and run okay but if I give it some gas, it will sort of sputter. There's a misfire in there but I'm not sure if it's the coil or a sensor of some sort that could cause the problem? Normally I'd just change the coil, the plugs are stock Ford replacement and have about 2000 miles on them. The wires are Ford Racing but they are old and the coil wire is God-knows-what but that wouldn't be enough to cause this problem.
I do have IAC problems from time to time but I doubt that could cause the spark to drop.
Does it change when the motor is hot or cold?
It doesnt sound like a spark issue to me, but rather an engine management/sensor issue.
Good luck.
thanks, I'll run my scantool to see if anything comes up... I wonder if we can just buy a sensor kit, you know a bag with every little stupid sensor the engine has.
There are numerous things that it could be, in addition to sensors (my above-post wasnt worded very well). A sensor kit would be nice, but VERY pricey and not necessary (it's money/time better spent to diagnose rather than toss).
Something like slightly dirty injector(s), a vac leak, etc can also all cause issues.
That's a great idea to start with the scan tool to get codes (I dont think you can get Fox PID's with many of the scantools out there, but I could be wrong).
I'm thinking that JR and the other wise ones will have some good ideas for you.
Good luck.
