Ok, first off I'm still running the stock catted h-pipe w/ flowmaster catback, and all smog equipment is hooked up. I've pulled codes, and I get an EGR code I've known about for a while, but I don't remember the exact number. I could figure it out if it's relevant. I don't have any thermactor system codes.
So this is really more annoying than a problem...
When I'm coasting down hill in gear, everything sounds normal at first. Then after about 10 seconds or so, all the sudden the exhaust gets really loud (lots of popping through the pipes). If I give it gas for a moment and let back off, it is quiet again, but then after another 10 seconds or so it gets loud again.
When it gets loud, it's instantanous, like a valve opened. I'm suspecting some part of the Thermactor system is pumping air from the smog pump into the exhaust when it's not supposed to.
I've found some posts on here describing the basic operation of the Thermactor system, but I didn't find anything indicating when and under what conditions the system opens the solenoids. I did read that it pumps air into the heads when the car is cold, and into the cats when it's warm.
Any suggestions? This isn't really causing any drivability problems, it just annoys the heck out of me. I usually just push in the clutch when coasting downhill to avoid this, but I would like to fix it if possible.
Thanks.
Jeff
Thanks.
Jeff
