problem with upr control arms
MT1083
1,033
Charlotte, NC
I'm doing all of my rear suspension right now and I've run into another problem. I was told by upr to reuse my factory lca bolts and nuts. One problems though...they won't fit into the holes of the bushings. The hole in the bushing is too small in diameter. Anyone run into this?
found the problem. They are supposed to send new sleeves so that you can punch out the smaller ones and use the bigger sleeves. Apparently they supply all the sleeves normally but they only sent me 2. I need 6 more in order to finish. So in case any of you run into that problem, now you know what to do. :nice:
