  • 2005 - 2009 Specific Tech
Problems after applying tune
  • Thread starter Thread starter larry3828
  • Start date Start date May 23, 2007
L
larry3828
21
Arlington, VA
May 23, 2007
  • May 23, 2007
I have an '06 Mustang GT with a 5-speed.
A few weeks ago I bought the C&L street CAI & SCT Xcal2 tuner package from Brenspeed. I also bought the Steeda underdrive pulleys. I put the CAI on and applied the 87 octane tune per the instructions, but I still haven't installed the underdrive pulleys. Gas is too damn expensive right now to go to the 93 octane tune. Besides, it's really a lot quicker even with the 87 octane tune!
My problem is my engine can't seem to figure out where it wants to idle. Usually when it's cold it idles at between 1500 and 2000 rpm's for awhile until it warms up and then it varies between 800 and 1000 rpm's afterward. It doesn't always do this, but it almost never idles below 800 or 850 and it seems to be varying its idle a lot of the time. Also, sometimes when I first start it up and begin to let out the clutch it will start to surge and continue to go up and down like I'm pushing down and letting up on the gas. I have to completely get out of the pedal to make it stop doing this. This doesn't happen all the time, but enough to be irritating.
Has anyone else experienced this? Should I reapply the tune? Or could this be happening because the tune is setup for the underdrive pulleys which I haven't installed yet? Any help with this would be much appreciated. Thanks.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
May 23, 2007
  • May 23, 2007
call brent. he will get it worked out for you.
05wolfkiller
114
pearland, texas
May 23, 2007
  • May 23, 2007
my car did the same thing after installing a c&l street intake and pred. tune. i did not notice any idle problems. but it ran rough for a few minutes, then everything was fine. i was told the computer has to "learn" the new tune characteristics. if this is happening on a regular basis well after a tune, i would definitely check into it.
iskwezm
4,159
20
79
Rowland Heights,California
May 23, 2007
  • May 23, 2007
My first tune that my buddy did for me had no issues and then i messed with the Xcal2 and it did the same thing you are decribing.
L
larry3828
21
Arlington, VA
May 23, 2007
  • May 23, 2007
So how did you get it fixed?
iskwezm
4,159
20
79
May 24, 2007
  • May 24, 2007
i havent yet. I could put the tune back to his tune, but im waiting for a retune to use the C&L, so i just deal with high idle and roughness when cold.
BlackRod
55
Southern California
May 24, 2007
  • May 24, 2007
I have the C&L Racer and SCT tune from Brenspeed. My car does something similar. It surges at idle for a few seconds when I come to a stop. Brent's explanation was the mass air was bigger, allowing more air in. This causes the idle to act screwy. He told me there isn't a fix for this, although I can't help but think bigger injectors might help... but I'm not a techie.
2bfeard
60
Covington
May 24, 2007
  • May 24, 2007
I have not had any problem like this on the 06, but with many fox body's i have, the fix for them was to open up the small hole in the throttle blade, hence letting the car get more air at idle when the throttle is closed, I would be willing to bet it would work with the s197's to. Good luck!!!
C
CPman
129
  • May 24, 2007
If you can, drive it for 3 or 4 days. My car did the same thing when I first progammed it , but it stablized in a couple of days and has been fine ever since (over a year now)
L
larry3828
21
Arlington, VA
May 25, 2007
#10
  • May 25, 2007
  • #10
Thanks for all the help, guys. My car wasn't acting quite so bad yesterday, so maybe it is just a matter of time and it will smooth out. I'm taking a trip this weekend and we'll see how it acts after that. Thanks again.
steedastang06
European Forum Founding Member
Feb 25, 2002
1,844
Ewa Beach, Hawaii
May 25, 2007
#11
  • May 25, 2007
  • #11
I had the same problem and when I asked Brent, who does all my tunes, he told me that FORD has a factory setting to allow the cats to warm up by adjusting the IDLE to run higher for a few seconds until they warm to the right temp and then return to normal idle.. I asked him to remove the setting and he resend me the tune and I have no problems now...
red05bullitgt
861
Pittsburgh, PA.
May 25, 2007
#12
  • May 25, 2007
  • #12
It's definitely not your underdrive pulleys Larry, because pulleys do not require any tuning.. So it would really be in your best interest, to follow Steedastang06's recommendation, by contacting Brent and have him remove the setting, and then send you an updated tune, as soon as possible..
BJ1000RR
58
New Orleans, La
May 26, 2007
#13
  • May 26, 2007
  • #13
Oh yes it could be the pullies, I just torqed my pullies down with an impact without going through the torque directions that come with the pullies, and my CEL kept coming on. When I checked the codes, it said cilinder misfire on #3 +#5.
I thought it was a problem with the tune, but when I called Brenspeed, they said the pullies are very sensitive and are to be torqed down the exact way the directions state. I did it right and no problems since.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
E
Nightmare after tune install!
  • EnemyofTyranny
  • Mar 29, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 12, 2025
89ripper
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
2005 - 2009 Specific Tech Sep 6, 2025
