  • 1994 - 1995 Specific Tech
Problems after Intake install.
  • Thread starter Thread starter zZsKyZz
  • Start date Start date Sep 13, 2007
Z
zZsKyZz
503
Sep 13, 2007
  • Sep 13, 2007
I just finished installing a Edelbrock RPM intake and now that I've started it I've noticed a Check Engine Light [CEL] and a rough idle then it stalls out. I also notice it having a loud whine or whistle after I rev the engine.
Any ideas? I did forget where I left the timing, but I guess that'd cause pinging if it was wrong..Not this rough crappy idle.
I already checked for vacuum leaks and solved all them... So I think.
Suggestions/ideas?
sleeperstang199
78
harrisburg, Pa
Sep 13, 2007
  • Sep 13, 2007
sounds like you have a vacuum leak. most people have problems with the lower gaskets. hook a vacuum gauge up to the intake and check your vacuum. i think it should be between 18 and 26 In/Hg.
R
red95gtconvert
382
Ponca city, OK
Sep 13, 2007
  • Sep 13, 2007
As mentioned above you have a vacuum leak, and from the way you describe it I would bet it is a big one. Do you have the unused vacuum ports plugged off on the upper intake?
Z
zZsKyZz
503
Sep 13, 2007
  • Sep 13, 2007
yep....i had to remove the whole intake cuz after i started it i noticed that it was there and I dropped a plug down the ****er... So I had to remove the whole intake to get that plug out.
...Trust me, that thing is plugged now.
M
mojopony
71
  • Sep 13, 2007
Yeah, I'd say put a vacuum gauge on there and check how many inches its pullin' and if it seems kinda low spray some carb cleaner around and see if the idle picks up.
Z
zZsKyZz
503
Sep 13, 2007
  • Sep 13, 2007
I think I'm just gunna end up selling the car. It's been nothing but problems and a hassle from day one.
Adam95GT
2,564
Burlington, NJ
Sep 14, 2007
  • Sep 14, 2007
chil out bro just another bump in the road... check your iac thingy???
Z
zZsKyZz
503
Sep 14, 2007
  • Sep 14, 2007
I've checked everything. It's driving me nuts.. If I have to take it apart again, it will be the third time I'm taking the intake on and off.
F
Fopar
178
San Marcos, CA
Sep 14, 2007
  • Sep 14, 2007
where u live? Maybe someone can come over and help you out
R
rdubb17
27
#10
  • Sep 14, 2007
  • #10
100 percent positive a vac leak. My friend installed my upper intake on my 2.3 and didn't tighten it down enough and it sounded like a supercharger (when it was turbo'd) Don't give up, figure it out man - its not that tough.
-Ryan
DLFD911
Fort Wayne, Indiana
Sep 14, 2007
#11
  • Sep 14, 2007
  • #11
+1 on the spray carb cleaner trick. I used to find every leak that way.
Dino Dino Bambino
1,672
89
79
Cyprus
Sep 14, 2007
#12
  • Sep 14, 2007
  • #12
I prefer water from a spray bottle to locate vacuum leaks on a warm engine. Carb cleaner's flammable and I wouldn't like to risk having a fire under the hood.
Like the others, I can guarantee you have a vacuum leak somewhere and it's most likely to be from any of the intake gaskets (lower intake to head, upper to lower intake, or TB to upper intake).
The rough idle is caused by air getting into the engine through an intake leak. Since this extra air isn't sensed by the MAF sensor, the computer doesn't add extra fuel so the engine runs lean and stalls.
M
mojopony
71
#13
  • Sep 14, 2007
  • #13
Some folks spray brake parts cleaner, but I don't know if its less volatile than the carb cleaner.
Z
zZsKyZz
503
Sep 14, 2007
#14
  • Sep 14, 2007
  • #14
Both are extremely flamable... I get bored at work sometimes and see which makes the best blow torch and chase my co-workers around with it...
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
