Problems After Replacing Alternator Form Stock To 100 Amp
mhjo
490
Oslo, Norway
I bought a 100 amp Tuff Stuff alterternator. We connected it as instructions suggested.
Car started and ran nice on idle. When I was driving the car suddenly stopped serveral times, as engine just died. It started nomally after stop, but engine died sever times + hesitatded at times too.
I have a MSD blaster coil, Mallory distributor with extra "circuit guard".
We pulled and wiggled all leads in order to provoke the situation, but it only occurs while driving.
What is going on?
What is different though, when the car is moving, VS sitting while you wiggle the wiring around? Maybe the motor move a bit in it's mounts, or there may be some more heat somewhere on a wire.
I understand what you are saying about the immediate change, but could it be coincidental? Can't hurt to check the switch real quick anyway..
what voltage output are you getting with the engine running? at what rpm does the engine cut out when driving? does it cut out when driving normally, or just when you romp on the pedal?
