  • 1994 - 1995 Specific Tech
Problems after spark plug change
  • Thread starter Thread starter Drew2o2
  • Start date Start date Apr 23, 2007
D
Drew2o2
10
  • Apr 23, 2007
Yesterday i put in some NGK V-power spark plugs along with a napa PCV. After this the car running a little funny in the lower rpms. It kinda bucks when at a low rpm and the engine appears to be shaking more than usual. I put the stock pcv back in to see it that helped, nothing. The car is 1995 5.0 5 speed with 103k. Any ideas on the problem?
1TallMF
955
Montreal
Apr 23, 2007
  • Apr 23, 2007
Check to make sure your wires are all making good contact on the plugs and that they all "clicked" into place. Every single time I've ever experienced a misfire or bucking, its always been plug wire related. Thats 4 times now.
go-stang5.0
2,244
Glenview,Il
Apr 23, 2007
  • Apr 23, 2007
Also make sure that the wires are plugged into the proper cylinders. YOu may have messed up the firing order by plugging a plug wire to a wrong spark plug.
HISSIN50
34
129
Apr 23, 2007
  • Apr 23, 2007
This is an awesome time to run a cylinder balance test. It will pick up the miss and tell you which cylinder is at fault. This saves checking every plug and wire and still wondering.
The CBT is part of the self test diagnostics. See your manual or code reader book for more info.
Good luck.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 23, 2007
  • Apr 23, 2007
Like JT said, do a CBT. I like to do it manually. It's easier IMO. Just get some good thick gloves..lol.
But go over the wires one more time, 13726548 counter-clockwise on the dizzy. No 1 cylinder is front pass. side, 4 is rear pass side, 8 is rear drivers side
Scott
D
Drew2o2
10
  • Apr 23, 2007
I know the plugs are in the right order as i only took one wire off at a time and i checked to make sure they were clicked. Im also gonna pull them out and check to make sure the gap is correct.
juicedcoupe408
JACKSON TENNESSEE
Apr 24, 2007
  • Apr 24, 2007
ALSO YOU MIGHT HAVE DAMAGED THE END WHEN PULLING THEM OFF WERE ANY OF THE A BIOTCH TO GET OFF??
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Apr 24, 2007
  • Apr 24, 2007
You might also check that none of the plugs cracked when you installed them. A cracked insulator will allow the spark to bridge directly to the block -- typically this causes bucking at lower RPM, and then smooths out as the revs come up.
F
Spark Plugs Caused Rough Idle & Driving
  • firevert
  • Sep 1, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 3, 2025
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
