  • 1994 - 1995 Specific Tech
problems fitting front drag wheels
  • Thread starter Thread starter NKau
  • Start date Start date Oct 24, 2007
NKau
1,346
Jefferson, WI
Oct 24, 2007
  • Oct 24, 2007
I'm having trouble with getting my new drag wheels to fit over my sn-95 front brake parts. I have some 15x4 centerline telstars that have 1.625" backspacing. The problem is that the backs of the rims hit the anti-moan brackets BADLY; wheels don't even come close to the face of the rotor. I'm pretty sure they'd still hit the calipers even if I ground the brackets down a little. Do I have any options outside of spacers and longer wheels studs? My next problem is, that I'm worried the wheels may stick out a bit with the spacer; I have '96 front spindles which I've heard are a little wider than the '94-'95 pieces. Any suggestions?
<!-- / message -->
96stangRC
14
  • Oct 24, 2007
As far as I know, the only other option outside of spacers is to actually cut that entire bracket off. I know a lot of people have done this without any problems, but I never felt quite right about chopping mine off so I used spacers. Even if you use a fairly small spacer, you may be able to get away with just grinding that bracket down rather than taking it completely off.
SQUEEZE&STROKE
SOUTHERN CA
Oct 25, 2007
  • Oct 25, 2007
I took the bar off, ground the caliper down and STILL had to use spacers. Just get the right spacer.
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
J
2003 convertible front brakes sticking
  • jamesbanasky
  • Jul 9, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 6, 2025
jamesbanasky
J
