So I am just a little frustrated today.
The 88, which is a MAF converted car, has started to misfire a little when you are just cruising, its fine if you are on the throttle but under light throttle it starts to miss. So I figure that I will dump the codes and see what it tells me. Well it doesn't tell me crap cause it won't dump codes. Plug the tester in and it doesn't do anything. Just sits there with the light on. No blinking no nothin.
I did a search and followed jrichkers advice in another thread. Pulled the battery and tested out the black/white wire on the test connector to ground. Got around .3 ohms. So that looks good. So I pull the computer out and and test the single wire, I believe it is white or tan w/red. and it ohms out fine from the computer plug to the test plug so its good. So I decide to test out the pins on the computer. I get either OL or roughly 3.3Mohms when I read between pin 46 and either pin 40 or 60. I used a nice Fluke 77 digital multimeter to do the testing. So it looks like the computer might be bad. Kinda bites but I have a 93 GT that is just sitting right now so I will just steal the computer out of it. Pull the battery and pull the computer and I go to check it just for grins and guess what. No continuity between pin 46 and pins 40 or 60 either. So now it looks like I might have TWO bad computers.
Just wondering if anyone can confirm if I am right or wrong before I go out and get a replacement. And what could cause them to go bad and what do I need to check before I put another in to keep it from crapping out.
I am just about ready to get the can of gas out and light this sucker on fire.
