problems with gas tank
scorp69
605
California
saturday morning i started my 93 just to let it run. later that day i was going to drive it and when i turned the ignition over it wouldn't start. my friend then noticed gasoline coming out from the rear end side. i haven't had a chance to look at it since i got busy, but what would you think it is? i thinking the fuel filter hose came loose, but i changed it a few months ago i the stang was fine. never seen this before. :shrug:
The tank grommet is likely (where the filler goes into the tank). They're a POS.
Unless you were parked on a funky incline, the tank shouldn't have drained down so far as to keep the car from starting however.
Good luck.
