Problems with injector pulse
1fast95stang
52
Has anyone ever heard of a 5.0 starting fine, then once its warm like 10-15 min the injector pulse will start to go and wont run. I have a 1995 mustang with a procharger and 42lb injectors any ideas???
Have you used a noid light to determine that the injectors aren't working? How did you come to that conclusion? There are no clues in your post to help.
Have you dumped the codes and see what the computer says is wrong? Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
