problems with modded 94 gt
corybens11
ok so i have a 94 gt that i havnt driven in a year or so because of school and what not but im getting back into it finally but i have a few problems, its a hci 306 with a 190 fuel pump 24 lb injectors 5 speed swap ect. One is that i have a really bad vibration in the shifter around 90 mph and up, i noticed that one of my wheel bearings is starting to make noise but i would think that would be more in the steering wheel if it was that.
second i got it tuned awhile back and the injectors were running at like 95 % duty cycle so he suggested i just went to 42 lb/ hr and a lightning MAF but it doesnt seem like anyone has these anymore, i plan on eventualy having around 550 to the wheels mayb a bit less with a 331 on boost, so would 42s support that or could i go to 60's but then it would probably be too big for my current 300hp set up right?
sorry for ranting but all help is awesome
thanks
cory
For vibration I would check the balancer, drive shaft, u-joints and wheels. For the 550 hp I'm certain that you will need bigger injectors and they can be tuned down to an idle pulse width. Your fuel pump will be inadequate as will the fuel lines. 42 lb injectors and 90 mm LMAF's are generally available so you shouldn't really have a problem finding them.
these are my mods, its kinda hard to believe its maxing out the injectors isnt it, but the tuner said they were at 98% duty cycle
Stock block .030" over
Federal Mogul Forged piston 10:1 compression rebuild kit
ARP connecting rod bolts and head bolts
trick flow top end kit
bbk Ceramic shorties with stage 8 locking bolts
frpp 9mm wires
bbk cai
summit 70mm tb
Gernatti MAF
Frpp 24# injectors
Kirbun FRP
smog pump delete
Flowmaster American thunder cat back
BBK o/r h-pipe (sounds sooo nice)
Trick flow elbow and 1 inch spacer
190lph fuel pump
180 thermostat
I had a real bad vibration like that before, and it was a U-joint in the driveshaft. Ended up shattering the back end of the transmission when I was 1000+ miles from home. I'd check the driveshaft first. 24lb injectors should be good for that HCI setup, even at 95% duty cycle. If it ran good like that, I wouldn't mess with it. For the MAF, you can just get a P-MAS. You don't need to hunt down a Lightning MAF.
Kurt
