  • 1994 - 1995 Specific Tech
Problems with OD
  • Thread starter Thread starter Kevin R.
  • Start date Start date Jul 22, 2004
Kevin R.
473
Ohio
Jul 22, 2004
  • Jul 22, 2004
First off, i recently had my transmission full rebuilt not 2 weeks ago.
Yesterday I was driving down the highway about 70, of course it's in OD, and i hit the gas no even half way and the car, when it hit about 2500 rpm, revved up real high like it was in neutral before it hit its gear. It did this about 7 times.
The thing is, not 10 minutes later, it stopped doing it...
Did the transmission people screw up or is this normal?
stunner6910
580
south texas
Jul 22, 2004
  • Jul 22, 2004
there's a sensor that messes up on our aode's. i'm pretty sure someone will chime in and give you a name for it. mine was doing the same thing and when i installed the shift kit, it disappeared.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jul 22, 2004
  • Jul 22, 2004
Ive seen a post with this problem at least 10 times on here...It still happens to mine once in awhile.
I STILL have yet to see someone come in here and state FOR SURE what causes that and how to fix it.. Thing is most of the good guys around here have 5-speeds, and very few here know much about our AODE's
RC
Kevin R.
473
Ohio
Jul 22, 2004
  • Jul 22, 2004
Should this have been fixed on a fully rebuilt tranny or is that not part of it?
I have a 1-year warranty on it so...don't know what to do.
stunner6910
580
south texas
Jul 22, 2004
  • Jul 22, 2004
if that's the case just take it back and let them figure it out. don't forget to ask after they're done what it was for future reference. i can't quite remember what the part was called, something like neutral safety switch or something to that effect. i do know that it was about $15-$25 at the local auto store. good luck
Kevin R.
473
Ohio
Jul 22, 2004
  • Jul 22, 2004
Ya but I don't want to take it back randomly if it wasn't something they should have taken care of.
They will probably screw it up more..haha..or put more scratches on my deck-lid.
gcomfx.com
3,690
Republic, MO
Jul 22, 2004
  • Jul 22, 2004
Mine will "act up" like once every 5 months and it's usually on a corner. Which is bad news cause it's usually like a neutral drop and the rear end wants to come around. Kinda hard to explain to the cops too.
SN95StangMan
1,292
Lynwood, CA
Jul 22, 2004
  • Jul 22, 2004
I too have this problem once in a while. I have read that it can be caused by the MLP sensor/ neutral safety switch going bad.
Kevin R.
473
Ohio
Jul 22, 2004
  • Jul 22, 2004
Do you think this should have been replaced?
gcomfx.com
3,690
Republic, MO
Jul 22, 2004
#10
  • Jul 22, 2004
  • #10
Depends on what you paid for the rebuild... but it's not really part of the tranny. It's like saying asking for new O2 Sensors with new exhaust....
I've been told that my problem since it mainly happens on corners could be because of the shift kit and the 1-2 shift being overdrilled. Fluid could be routed a different way causing the problem. Or the plate is flexing...
94GTLaserRC
11,178
Jul 22, 2004
#11
  • Jul 22, 2004
  • #11
Couple of things:
I have read something about a cheap sensor switch which causes that, and I DONT believe it is part of a Tranny Rebuild.
FOI: what did you have done to your tranny, and what did it cost you?
Thanks
RC
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Jul 25, 2004
#12
  • Jul 25, 2004
  • #12
damn!!.... posted with my bros again insted of Kevin R.... anyway ...
Cost $1589 tax and all for complete rebuild with 1yr unlimited mileage guarantee and fluid change at 12 months included.
The bill shows new parts were.... torque converter, direct drum, overdrive spring low speed bands x 2, torrington bearing kit, thrust washer set, bushing kit, tcc solenoid, epc solenoid, shift solenoids, valve body recalibration kit, steels, gaskets, lip seals, sealing rings, friction plates, filter, 12 qts mercon5, flush lines.
Shop said dont worry about it, they will check it out anytime I bring it in ... codes or something... and just let them know if anything like that happens again.
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
#13
  • Jul 25, 2004
  • #13
that seems alot for a tranny. ain't no way i'll pay that much!!!
94GTLaserRC
11,178
Jul 25, 2004
#14
  • Jul 25, 2004
  • #14
That's really not a bad price.
The parts from Art Carr for rebuild will run me about $700, and I found a shop that will do the labor for about 450...That's for PERFORMANCE parts, but that does NOT include the TQ Conv or shift kit, which I already have. However the shop I found is family run, and the guy who would do my work owns a 95 stang, and he does work for a lot of cars that run at Moroso race track.
Just keep on them about the work.
RC
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
p0740
  • Roont
  • Oct 19, 2025
2005 - 2014 S-197 Mustang -General/Talk- Oct 19, 2025
horse sence
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
