Professional Products - Powerforce Dampner Questions
IndyBlk5.0
1,122
New Whiteland, IN
Professional Products - Powerforce Damper Questions
I got a her powerforce damper becuase mine was falling apart... It is a 6.40"" SB Ford (50 oz.) part number 80007. I need to know how to check if this is the correct dampner, it says its for it, but i dont know if i need a spacer with it or not (it did not come with one) how do i tell? :shrug:
Well i need a spacer evidently, it is too short... i compared the two, the damper (powerforce) was sitting were it should have been (according to water pump pulley) before it was pounded in. So i put the stocker back on the crank in the same position, about an inch or so longer, the exact length that you have to pound the new damper into the engine on the crank... GURRRR i have to wait until monday then wait agian for the diff part!!!!
or some just slide it on far enough (anti seize is a good idea on the hub) so that the bolt threads on. then tighten it up.
good luck.
