Progress update....broken glass
  • Thread starter Thread starter mustangman70
  • Start date Start date Dec 8, 2006
M
mustangman70
1,235
St pete, Florida
Dec 8, 2006
  • Dec 8, 2006
Well i got the rear end out...
Got the fuel line and parking brake cable out...got the headliner out and everyother piece of rubber or nut and bolt....exept for the glass...
And i ****ed up my windshield
I cut around it with a knife but when we went to go puch it out it cracked in the driver side bottem corner
As soon as i get the front and rear glass out its ready for blasting...im pissed
That is all
G
Gailahan
144
St. Louis, Missouri
Dec 8, 2006
  • Dec 8, 2006
Well, at least windshields typically aren't as expensive as the other glass on the car.
jes72mustang
224
S. Central PA
Dec 8, 2006
  • Dec 8, 2006
Cute video of van dam...
N
Nemesis67
146
Las Vegas, NV
Dec 8, 2006
  • Dec 8, 2006
I've got everything stripped out of my 67 FB too. Nothing left on it except the rear end and front suspension. The only functioning system on the car is the brakes! Sorry to hear about the glass I got my glass out with no problems. But I guess that's because all of my seals where completely dry rotted (hard as rocks). And barely holding the glass in!
bnickel
5,640
lubbock, texas
Dec 9, 2006
  • Dec 9, 2006
starting in 69 Ford went to a urethane ribbon sealer instead of the older style gasket. it is very difficult to remove a 69/70 without breaking the glass. look at the bright side though, even if the windshield was only a few years old they are almost always pitted and scratched anyway. i got a brand new PPG windshield INSTALLED in my car for 150 bucks.
69gmachine
576
Southern Maryland
Dec 9, 2006
  • Dec 9, 2006
Just in case you need to do this job again sometime, I was told by a body shop that the trick was to use a thin wire to separate the glass from the sealant. The '69s are pushing 40, and most will have had the windhsield removed/replaced at sometime, so odds are the sealant will be fairly new even if the glass isn't.
Use an awl or something similar to push the end of the wire through the sealant near a corner. Then with a buddy on one side and you on the other, slowly saw and pull it around the perimeter of the glass. Once it's cut all the way around, make a second pass. Be careful not to put any weight on the glass that would cause it to reseal somewhere. Then lift the glass carefully from the inside, first from one end then the other. I have had my same glass in and out three or four times and haven't cracked it so far. Unfortunately, I got grinding spatter on it and burned tiny little holes all over. I have the replacement glass, but visibility wasn't as bad as I thought it would be, so I decided to wait until I get ready to re-do the paint to install it.
J
  • JRC99
  • Apr 19, 2025
JRC99
J
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
SOLD Restored 1986 Mustang GT
  • MRaburn
  • Jul 12, 2021
9K
Fox Body Mustangs For Sale (1979-93) Jul 12, 2022
Brakes 1979-1986 Fox Parking Brake Adjustment
  • LiquidStangs
  • Sep 22, 2019
10K
Fox 5.0 Mustang Tech Sep 23, 2019
LX Dave
I
Exorcising a '78
  • IICrew
  • Mar 29, 2020
  • 13 14 15
35K
1974 - 1978 Mustang II Talk & Tech Oct 2, 2026
2Blue2
