Progress update - pics
  • Thread starter Thread starter 67GTFastback
  • Start date Start date Sep 2, 2004
67GTFastback
1,210
Calgary, Alberta
Sep 2, 2004
  • Sep 2, 2004
I have installed and welded the torque box and toe panel. The cowl has been repaired and painted the color that the car will be, and the front left fender apron is in place (I still have to clean up the shock tower). Here are some pics.
blascrw
191
Opelika, AL
Sep 2, 2004
  • Sep 2, 2004
looking good
Wow did you do the work yourself?
Want to come spend some time in Alabama and do some work on mine...
I could get you tickets to an Auburn game
Seriously looks good!
Ron
67GTFastback
1,210
Calgary, Alberta
Sep 2, 2004
  • Sep 2, 2004
Ron
Thanks. Yeah, I am doing ALL the work myself, with the exception of the motor rebuild. That is going to have to wait.
66 BLAKE 96
Native Texican
4,810
Cowtown
Sep 2, 2004
  • Sep 2, 2004
Wow!
You aren't kiddin' around there man.
O
Ozsum2
695
  • Sep 2, 2004
What is the color? Sort of a rose-gold-copper?
67GTFastback
1,210
Calgary, Alberta
Sep 2, 2004
  • Sep 2, 2004
The color is going to be a copper color, that is some off the shelf spray paint I bought to give the person I am doing the car for an idea of how it will look. He really likes the new copper color of the Nissan Murano's so we are going to do a color along those lines.
68Coupe289
234
Lexington, KY
Sep 2, 2004
  • Sep 2, 2004
Looks solid man. I wish I had a work area sufficient to learn bodywork.
67GTFastback
1,210
Calgary, Alberta
Sep 2, 2004
  • Sep 2, 2004
I have a 22'x22' garage and it feels tiny right now.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Sep 2, 2004
  • Sep 2, 2004
It doesn't look like you braced the door areas before cutting out the floors. It looks as if the car has already twisted from the pic. I have seen a pic of one that caved in!
66 BLAKE 96
Native Texican
4,810
Cowtown
Sep 2, 2004
#10
  • Sep 2, 2004
  • #10
How can you tell from these pics?
The car should be fine if the floors are cut and replaced one side at a time.
67GTFastback
1,210
Calgary, Alberta
Sep 2, 2004
#11
  • Sep 2, 2004
  • #11
How can I measure that to make sure it hasn't twisted? I have measured along the frame rails and everything is nice and square right now up front. The car is at an angle in the pic, it wasn't levelled when I did that. Here is another pic from a different angle.
67GTFastback
1,210
Calgary, Alberta
Sep 2, 2004
#12
  • Sep 2, 2004
  • #12
That is how I am doing it, driver side first.
67GTFastback
1,210
Calgary, Alberta
Sep 2, 2004
#13
  • Sep 2, 2004
  • #13
Come on, don't leave me hanging, please explain, how can I measure this? Is it possibly the angle of the pic? I only have one side out at any given time.
D
dmoody
789
Winston-Salem, NC
Sep 3, 2004
#14
  • Sep 3, 2004
  • #14
I'm not an expert here, however I'll attempt to share my opinion. Your rocker panels, roof, door pillars, torque boxes, etc form the structure that holds the two subframes (front and rear) together on a unibody car. Your floor panels, firewall, cowl box, etc individually add small amounts of support to the overall integrity of the structure. However given that you replaced the full cowl box, driver's side torque box and full floor panel all at once... I could see where you might loose a little bit of alignment. I wouldn't think the structure could collapse because you don't have any weight anywhere... you've removed the doors and everything in the engine bay. I think if you proceed in the future removing and repairing one thing at a time you'll be fine. That is what I done on my 68 fastback. I personally think bracing the doors to simply remove the floor panel is overkill on a coupe (convertible -yes). However the condition of your torque box is the only thing that worries me about your whole restoration. On the passenger's side you might try replacing the torque box before cutting out the floor panel. Overall I think you are doing a good job and I certainly can't discount your enthusiasm for this restoration... it looks like you've put a lot of hard work into it.
d
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
What is it Worth?!?!? May 18, 2026
nickyb
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
What is it Worth?!?!? Jun 13, 2026
KRUISR
