  • SN95 V6 Mustang Tech
projector headlights in a 1997 mustang
  • Thread starter Thread starter shack
  • Start date Start date Feb 8, 2011
shack
  • Feb 8, 2011
Hey everyone,
Im a college kid and im slowly trying to make my car look a little nicer and improve lighting when i drive at night. My stock headlights now are yellowed and dont put a lot of light out. Im thinking about switching to some projector headlights that i found on Carid.com. A friend of mine had boughten a '98 mustang that already had projectors in it and he said they were terrible and didnt have good light out put at all. Has anyone installed projectors in their car? And have you had any trouble with the lens' fogging or the light output being bad?
Thanks
Skymarshal
572
Dallas
Feb 8, 2011
  • Feb 8, 2011
The thing about projectors- even well designed projectors- is that they have a sharp cutoff above the beam. That makes it critical that they are adjusted correctly. They need to be high enough to put light down the road, but not so high that they blind oncoming drivers.
You also have to make sure that they are DOT listed. Some of the aftermarket lights available online are intended for off road use only. That means they've just been designed to look cool- not to light the road safely without blinding other drivers.
I have DOT projectors with HID bulbs and I'm pleased with them. They put out more light close in, but the cutoff takes some getting used to. I am sure that I would have a better chance at seeing something like debris or a deer in the road with my old lights than with the new ones assuming i'm using the low beams. Closer in however, they light the road much better!
R
robb15033
67
  • Feb 15, 2011
I had projectors on my '97 and installed the Osram Night Breakers to get proper vision and not go HID. I also got matching 5000k LED Switchback turnsignal bulbs to match. Looked great.
They now have a brighter CCFL, so make sure you get the most current version. Check out the LED Switchbacks too.
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
J
  • JRC99
  • Apr 19, 2025
JRC99
J
Introducing the All-New SL2 LED Replacement Bulb | Diode Dynamics
  • Diode Dynamics
  • Mar 21, 2024
  • Vendor Sponsor Forums
Vendor Sponsor Forums Mar 21, 2024
Diode Dynamics
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
