propane
  • Thread starter Thread starter shttygtstang
  • Start date Start date Oct 15, 2004
shttygtstang
978
  • Oct 15, 2004
has ne 1 used propane before i head there where good gains like nitrous whith out there being much damage because it burns at lower temps
mustangjoe87
364
Harrison Twp., Michigan
Oct 15, 2004
  • Oct 15, 2004
isn't that a diesel only thing? or atleast thats what i thought.
shttygtstang
978
  • Oct 15, 2004
no cars 2
Scorcher2005
883
South Carolina
Oct 15, 2004
  • Oct 15, 2004
i was also under the impression it was only for diesels too...
shttygtstang
978
  • Oct 15, 2004
its not its like hi octane gas im shure
whtpny
338
Spokane WA.
Oct 15, 2004
  • Oct 15, 2004
I will provide the setup for it. and heck you can even come over to my house to install. I just want to see what happens? I seriously don't think it will do a damn thing for you unless you have the high compression of a deisel. But who knows I will have the BBQ unhooked before youget here.
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Oct 15, 2004
  • Oct 15, 2004
anybody else know any info? im veryyyyy interested in hearing some more about this topic
F
frmus3
Banned
Sep 2, 2004
39
  • Oct 16, 2004
Put propane in a diesel and its boost. put it in a gasoline engine and its slow. propane goes in alot of trucks and suvs for an alternative fuel (You generaly get better MPG and the fuel is usally cheaper. here in AZ you get a special lane on the freeway and my license plate went from about 900 a year to like 100 for two years!) i have it in my truck and having 60gallons of fuel in the back plus 25gallons of gas is nice for a smoother ride (weight) and for road trips. if it can be done to my truck im sure it can be done to car. i got a 6.0L V8 that is kinda quick considering weight, but when i flip the switch to propane its time to turn up stereo and cruise cause it gets SLOW!
T
TheUser
1,859
Springfield, MO
Oct 16, 2004
  • Oct 16, 2004
Why would you get a special lane for using propane? 60 gallons...what do you drive, a semi? Good grief. What does using propane have to do w/ the price of your license plates?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 16, 2004
#10
  • Oct 16, 2004
  • #10
Shttystang - there's no particular benefit to injecting propane like you would nitrous. Nitrous works because it is oxygen-rich. You get more oxygen in the cylinder without having to flow more air. With more oxygen, and the fuel to burn with it, you get more power.
Propane is just another carbon based fuel like gasoline or natural gas. And it has a much lower specific energy content than gasoline. So if you take two identical engines, and run one on gasoline and one on propane, the propane powered engine will make 20-30% less power than the gasoline engine. It does have a higher octane than gasoline - so if you built a propane-specific engine, you could run very high compression ratios -- that would return some of the power/efficiency compared to gasoline. Of course if you did that, you wouldn't be able to run pump gasoline in the car because the CR would be too high.
All injecting propane is gonna do on a naturally aspirated engine is richen your mixture which will likely cause you to loose power. Now on your supercharged motor - injecting higher octane propane to both richen the mixture and cool the chamber may allow you to run more boost/timing without fear of detonation. Talk to the turbo guys that are injecting methanol/water to cool the chamber -- they might be able to guide you.
With turbo diesels - people inject propane as a way to richen the mixture and cool off the chamber - allowing more boost to be added. It's like using methanol injection on a gasoline powered, turbocharged engine. No useful benefit for that on most naturally aspirated motors built to run on pump gas.
Many areas allow alternative fuel (propane is an alt fuel) vehicles and to use the HOV (high occupancy vehicles) with only one person in the car; most HOV lanes require 2 or 3 people in the car. It's their way of providing an incentive in large congested cities for people to drive less poluting vehicles. Properly tuned, propane and natural gas powered vehicles put out less polutants than their comparable gasoline counterparts.
D
Daggar
3,902
#11
  • Oct 16, 2004
  • #11
Because it burns cleaner and some states offer a discount because of that. Propane in a Mustang??? Not for this kid. The power differences Michael mentions in his post are real. It's not a performance fuel, it's and environmentally friendly one. Propane is actually a by-product of refining both natural gas and oil refining. The BTU for propane is higher per cubic foot than natural gas and condenses really well (somewhere around 14:1 when pressurized and liquified). Makes it easy enough to use as an alternate fuel but still does not have near the BTU per volume of gasoline.
pisgahhiker
148
Western North Carolina
Oct 16, 2004
#12
  • Oct 16, 2004
  • #12
I see alot of power strokes filling up tanks at the local lp station but I think that it's only a diesel thing.
I have seen a school bus that runs only on LP though.
Just get a NOS system unless u drive a diesel.
88stangmangt
2,332
Stafford,VA
Oct 16, 2004
#13
  • Oct 16, 2004
  • #13
we have fork lifts and man lifts at work that run off of propane for inside cause it is cleaner not because of more power. i dont think it would work on a diesel unless you mixed it with diesel....because diesel doesnt use spark only high pressure to heat up the fuel and cause it to combust but on the other hand propane needs a fat spark like gas vapor.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 16, 2004
#14
  • Oct 16, 2004
  • #14
Propane ignites in the diesel chamber quite well. Once the diesel starts burning spontaneously because of compression ignition - it will ignite the propane. Burning diesel fuel provides more "spark" than any electric-based ignition system ever could. The propane and natural gas only school buses can be spark ignited or compression ignited. Some are simply gasoline engine conversions to alternative fuel. There are some diesel conversions that run 20% diesel/80% natural gas or propane. The diesel fuel is ignited by compression and it sets off the rest of the fuel. These are 'old school' (no pun) conversions however; 'green diesel' technology and tougher emissions standards are causing the diesel engine manufacturers to be able to produce engines that run as cleanly as gasoline/propane powered engines provided low sulphur diesel fuel and particulate traps are available. I consult with International Truck and Engine - it's amazing what's coming with diesel engines. I suspect we might be seeing LOTS of small diesel-engine powered electric hybrids before it's all over. Our kids kids will be modding electric motors for more power.
....and you're absolutely right - most fork lifts run on natural gas or propane because they usually spend at least some time in enclosed spaces; and they run much cleaner than gasoline engines do.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
