  • 1994 - 1995 Specific Tech
Proper Pilot Bearing for 2.3 T5 to 5.0 engine
  • Thread starter Thread starter Hickfied
  • Start date Start date Dec 21, 2011
Hickfied
413
Morganton, NC
Dec 21, 2011
  • Dec 21, 2011
I've done this before and IIRC I used a pilot bearing for a 83' Ranger 2wd with a 2.2L diesel engine. Well I ordered that pilot bearing, and took my 5.0 bearing out of the crank. Wouldn't you know, the swap bearing has the correct I.D. for the 2.3 t5, but the O.D. is to small for my crank (my 5.0 pilot bearings O.D. is a good bit larger).
Do the 94+ crankshafts have a larger opening for the pilot bearing or did I receive the correct box, with the wrong bearing in it?
(Yes, I have a fox bellhousing to go with the 2.3 T5)
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Dec 21, 2011
  • Dec 21, 2011
I never could find one that fit right , I had local machinist make a bushing , if you can find a good machinist shouldnt cost too much
Hickfied
413
Morganton, NC
Dec 21, 2011
  • Dec 21, 2011
Answered my own question. There are two different bearings listed for the Ranger at Autozone. One only replaces the bearing, and the other replaces the bushing/bearing combo with a sealed roller bearing. The sealed roller bearing is the part needed for the swap (at 2x the price).
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Dec 26, 2025
AeroCoupe
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Fox 5.0 Mustang Tech Apr 13, 2026
Foxbodyjake
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
