O oldno7 Member Mar 27, 2010 109 1 18 Aug 15, 2010 #1 Aug 15, 2010 #1 i did the 5 lug conversion and used 95 spindles nut my ps wheel rubs the top of the strut tower. i lowered the car too.
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,260 17,945 224 Massachusetts Aug 15, 2010 #2 Aug 15, 2010 #2 Does the wheel lean inward? What wheel size do you have? So the inside of the wheel rubs the strut? Or the wheel hits the fender?
O oldno7 Member Mar 27, 2010 109 1 18 Aug 15, 2010 #3 Aug 15, 2010 #3 245/45/17 are the front wheels the driver side is ok its just the passangers side that rubs the strurt at the top fender is ok
Blandnuts I don't swallow; I only swoosh Founding Member Aug 21, 2000 1,172 124 124 FloorDuh www.dodo-brown.com Aug 15, 2010 #4 Aug 15, 2010 #4 What rims? Did you align the car? What were the measurements? How low did you lower it?
2000xp8 SN Certified Technician Aug 8, 2003 8,029 1,621 194 NJ Aug 15, 2010 #5 Aug 15, 2010 #5 Im not so sure if he aligned it, it really matters. The strut is in a fixed position when connected to the spindle. Sounds like the wrong offset rims to me.
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,260 17,945 224 Massachusetts Aug 15, 2010 #6 Aug 15, 2010 #6 Could also be a loose spindle to strut nut causing the wheel to ****. We need more info.....lots more. What wheels are on it? What is offset and bs? Does the wheel lean in? Etc etc
