I have a 95 GT 5.0 with 16K original miles on it.
Everything is as it was when the car was delivered.
It's mostly garaged and every 15/20 days, at least, I run the engine and move the car a little bit.
Once and a while, I drive it for 1 or two hours.
Well, recently the Check Engine lit.
It is intermitent... goes on for a couple of seconds, then it goes of. Minutes later, goes on for a little longer, goes off. And so it goes, usually for very short periods of time.
The car, though, runs nice and smoothly, despite the check engine light! No noticeable effect on performance.
I pulled the codes:
181: Heated Exhaust gas Oxygen sensor - Voltage signal not switching: Indicates lean during part throtle engine operation (BANK #1)
189: Heated Exhaust gas Oxygen sensor - Voltage signal not switching: Indicates lean during part throtle engine operation (BANK #2)
Not other codes at all.
Has anyone experienced that before? Any ideia what might be the problem?
Any input will be appreciated!
Many thanks!
I pulled the codes:
Many thanks!
I should drive it more, I know, but it is kept garaged away from home...this is my fun car. I am saving it
