pulled engine apart
  • Thread starter Thread starter alecracing
  • Start date Start date Apr 2, 2009
A
alecracing
18
Ft Lauderdale, FL
Apr 2, 2009
  • Apr 2, 2009
We bought a '95 Mustang with a 351W in it for our students to build into a "Drag Car"
Well, I had the students pull the 351W out
Compression and leakdown were good except for Cylinder #5 so I figured we would freshen the thing up with new rings and bearings. Found out that the pistons are .040 over, the connecting rod bearings were showing a lot of copper, the cylinder walls look scored, and the crankshaft is grooved on some of the rod journals.
So I was looking into stroking it and found that you can have the crank reground to a 3.7 inch stroke. That and a .060 bore should give me a 383. I don't really like going that big with a bore, but from the looks of the cylinder walls, it's either that or start with a new block since it's already .040 over.
Question is:
Can I use this crankshaft? What do they grind to make it offset? What are the best pistons and rods to use?
and
with a .060 over bore is a power adder going to be a problem?
REMEMBER: this is a RACE ONLY car...no street driving, just strip
347HO
462
Seattle
Apr 2, 2009
  • Apr 2, 2009
I suggest you have that block "sonic checked". Doing this will give you information on how much wall is left, and how symmetrical it is 360* for each cylinder.
Offset grinding the crank will include cleaning up your mains and offset grinding your rod journals.
Probe makes nice pieces at an affordable price. I have a distributor with prices that probably can't be beat.
If the block is useable after 4.060" bore, I also suggest you half "fill" it, and use a good girdle to keep your "cap walk" to a minimum.
Good luck with your project! I envy your students... wish my school had done this when I was a kid.
Dana
A
alecracing
18
Ft Lauderdale, FL
Apr 2, 2009
  • Apr 2, 2009
What is a good block fill?
I need to find a good machine shop around here
Modular2v
3,222
23
99
oklahoma
Apr 2, 2009
  • Apr 2, 2009
I think he is refering to grouting it....It will take away from the cooling capacity though.
A
alecracing
18
Ft Lauderdale, FL
Apr 2, 2009
  • Apr 2, 2009
Yes, I understand what he means but I have never had a Drag Strip ONLY car so i have never filled a block before. I was just wondering what people use to fill the block and how high they fill them.
Since it won't see the street, I doubt if cooling will be a problem
347HO
462
Seattle
Apr 2, 2009
  • Apr 2, 2009
Hard Blok brand is one type.
Moroso also makes a 2part filler.
Absolutely need a "good" to "great" machine shop. Finding one is the difficult task.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
G
4.6L rods and piston into a 5.4L
  • Green mustang
  • Jun 11, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 11, 2025
Green mustang
G
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
R
351w stroked to 408 CARB
  • Ric4eyedFox
  • Mar 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2025
General karthief
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
