I think I have an injector problem. Others' thoughts appreciated.
I blew a hg so I pulled the driver side head. Engine was bored & stroked 10,000 miles ago. When I pulled the head, the #7 piston looked different.
Here's what I see:
1.#7 piston top was a coppery color with a small amount of crud on the top. Other pistons had a dark burn coloration.
2. Lower intake runner to # 7 was also only slightly discolored, others had the black burn coloration
3. # 7 plug: ceramic insert is a dark gray and the tip is dark with only a small off-white spot. Other plugs ceramic inserts were white and the tips were a consistent off white/light gray color as expected. #7 plug was a wet on the end of the threads when pulled.
These plugs have about 5,000 miles in the engine (Autolite 3923), the #7 plug wire works fine. The injectors are 36 # that have been on the car for 45,000 miles. I got the injectors used.
One other cylinder plug (#2) shows some of the same ceramic insert coloration though the tip is just a little darker than the other plugs and it was dry when pulled.
I'm thinking the #7 injector is not spraying well and may be clogged. I am sending the injectors out for cleaning and reconditioning while I have the car apart.
Any thoughts or suggestions from others understanding these symptoms is appreciated.
Here's what I see:
