I decided to pull my codes today to see if anything is up. Here are my results:
Vacuum - 15-20 inches at cold idle
KOEO:
On Demand -
Code 85 - CANP (Canister Purge) solenoid circuit failure. - No idea?
Code 23 - Says TP Sensor out of range. - I haven't checked the TPS voltage though
Continuous Memory -
Code 33 - Insufficient EGR Flow detected - This is to be expected as my EGR is bypassed with the explorer intake.
Code 66 - MAF below minimum test voltage - Not sure? I recently cleaned the MAF sensor.
KEOR:
Code 94 - Thermactor pump - To be expected, smog delete
Code 44 - Thermactor pump - Same
Code 33 - EGR Flow - To be expected
What do you guys think about some of the wierd codes? Like 66, 85, and 23.
KOEO:
On Demand -
Continuous Memory -
KEOR:
