stab the distributer?? whats that mean? and which one is number 1 and how do i know its the compression stroke? and then i just point the light at the balancer and it will light up the degree mark im at? also should i mark the balancer at 10* with some white out or something so i can see the mark(its rusty) thanks for the help!
Stab is just one of those different words used for ... install
You Know ......... Like:
slug is piston
dizzy is distributor
hole is cylinder
etc
#1 is passenger side front of motor
2,3,&4 are behind it in that order
#5 is driver side front of motor
and
6,7,&8 are behind it in that order
As for the compression Q .........
You can stick your finger over the plug hole and feel the air being pushed
around your finger as the slug comes up in the hole as things are just
about right for the big bang don't ya see
Since you got a 50 50 chance of being on the correct stroke
I've never worried about all that and just line up the hb on tdc
cause if it is right .....
The motor will easily fire right off the bat and rev freely
and
If by chance it is not on the correct stroke ........
The motor will not fire as easy and will rev up rough and ragged
sooooo
When I've seen that happen ...I just position the rotor 180 degrees
different and the motor fires right up and all is good to go
#1 on the dizzy is usually marked on the cap and you "stab" it in such a
fashion that .........
1) #1 slug on the compression stroke is tdc
2) the hb is lined up at tdc
3) dizzy rotor is pointing at #1 plug wire
Yes ... a chalk mark of white or lime green helps a good bit
You take the spout out and line up the edge of the timing indicator
with the mark on the hb you have chosen to use.
Don't forget to put the spout back
and
Don't put the spout anywhere on the car while you are doing all this
or
You stand a chance of loosing it while testing
Cause you forgot to put it back
Grady
