I decided to pull the coded on my 88 and can only conclude the SCT chip is screwing with the readings..or I have HUGE problems. The car starts fine at 1400 or so,but the cold idle will fall off a touch quickly and drop the RPM's to 500-600 for a few seconds (5-10) before increasing RPM again to the 1200-1300 rpm range and holding constant for near a minute or so at which time the idle will work it's way to the 900-950 range where it's been set. Once this issue is run it's course the car starts and finds idle perfectly every time. So with this I decided to see if it was just a characteristic of the new chip program or another issue...so I pulled the codes. KOEO codes are 15...which I attribute to the SCT overriding the computers original program..so I disregard as the car runs flawlessly both in drivability and all around. NOW comes the interesting part....KOER test. Once started the test begins..idle up and down testing exactly as it should..HOWEVER the reader indicated a 6 cylinder is being tested...it runs the test and reveals to me an 11 upon complettion...this indicates no codes issued and test passed!! How unusual is that! Again did the test..same result, perfect performance from the vehicle..good milage...recent dyno indicated no issues and good power..but the reader is a little confused I think!!
