First the starter. Getting to the top bolt is not difficult at all. Remove the H-pipe first. total of 8 bolts or nuts, two at each exhause manifold, two on each rear exhaust flange connection. Don't forget O2 connectors or you can rip a wire off an O2 sensor and get to buy another one.
Once you have that off, with the car on ramps, get underneath with your head about even with the starter, your feet pointing to the rear. Use a 1/4" ratchet with an extension just long enough to reach the bolt head and clear the end of the starter. You can now use your left hand to touch the top bolt head, and use your right hand to put the ratchet in the correct area. Use your left hand to guide the socket onto the bolt and out it comes. You can even see the bolt head if you have your head located in the right place, but it is not easy to see and get your left hand up there. It takes about 30 seconds to get it out this way. It goes in the same way and is just as easy.
Are you going to pull just the engine? If so you will want to pull the tranny out the bottom. Two bolts on top, three on the left side, two on the starter side, and two on the bottom thru the steel dust shield. After you remove the linkage and the rear support, it will come right out. Best way to get the top to bolts is to remove everything else first, including the shifter and rear support/mount. WIth a jack under the transmission, lower it some and by laying under the car and looking up over the tranny from the rear you can see the two bolt heads you need to remove. I use long extensions to reach them with a u-joint on the socket end...
Getting the motor out is straightforward once you disconnect and mark everything. Once you get the lift hooked up, and remove the engine mounts, raise it a couple of inches and then check to make sure you didn't miss a wire or hose somewhere.
