pulling the engine!
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Sep 18, 2008
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 18, 2008
  • Sep 18, 2008
So is it easiest to pull an engine by removing the trans first (5spd) or just unbolting the engine from the trans and leaving the trans in the car?I dont have the ceiling heith to pull them together! And i need to do this work quick! peace
john
ID89GT
1,659
18
49
Spokane Valley, WA
Sep 19, 2008
  • Sep 19, 2008
I just pulled the engine only, just be sure to support the transmission for when you break the two loose
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 19, 2008
  • Sep 19, 2008
yeah huh! how many bolts in the bell housing i got one of those cheap little 1 1/2 ton jacks that works great for that!peace
john
NKau
1,346
Jefferson, WI
Sep 19, 2008
  • Sep 19, 2008
If you pull both the engine and tranny together (I think this is by far easier), put the rear of the car up on jackstands. You can literally almost pull the motor/tranny "straight out the front" in a very easy manner. This way you don't have to tilt the motor/tranny at an extreme angle to get them in/out.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 19, 2008
  • Sep 19, 2008
if i jack the rear up i dont think the cherry picker will fit under the front of the car cause it's lowered and almost dosent fit now. peace
john
stykthyn
5,232
2,652
223
gainesville
Sep 19, 2008
  • Sep 19, 2008
pull the driveshaft and disconnect all your connections(exhaust, electrical, clutch) while the car is still in the garage. then push the car outside and undo the motor mounts and tranny mounts. the motor will pull right out along with the tranny and then you can push the car back inside. unless it's raining and then this wont work
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 19, 2008
  • Sep 19, 2008
Definitely pull the engine and trans as a single piece. Stabbing the trans back in the clutch while the engine is on a hoist is difficult and frustrating. The primary issue is having sufficient clearance under the car to get the shifter past the trans tunnel. I had mine on jackstands on all four corners.
There can be clearance problems between the ceiling and the cherry picker hoist if you are in a garage with a low ceiling or under a garage door opener that hangs down low.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 19, 2008
  • Sep 19, 2008
The new motor wont be in till november cause i'm redoing all the under the hood stuff again. i have 99% of the parts for my 351 so it's assembly time then reinstall. I;m sending my 3550 off to get the pro50 shift kit installed in it as well. peace
john
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 19, 2008
  • Sep 19, 2008
well i dont want to push the car out, i was only pulling the trans seperate cause i'm not to that point yet and i have the old 5.0 sold this weekend. BUT now i might of ran into a snag! I busted up my finger bad at work today so i have a splint on it peace
john
vristang
4,933
101
124
Seattle
Sep 19, 2008
#10
  • Sep 19, 2008
  • #10
No excuses John... pull that motor!
I did my 351w swap in the week after having my knee scoped.
I've always pulled the motor and the t5 as a unit.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 20, 2008
#11
  • Sep 20, 2008
  • #11
LOL yeah huh! the only thing stopping me with the finger is i have a stupid splint on it! my finger got in the way so i decided to TRY to grind it off! to bad i only made it 1/2 threw nuckle! trust me come wednesday/thursday it will be 99% out. i work fast. peace
john
  • Poll Poll
Pull engine & trans together or just engine?
  • ShawnR
  • Jul 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 2, 2026
RaggedGT
C
Inline 6 wanted 200 ci
  • Capnkev
  • Mar 2, 2026
  • Want to Buy
Want to Buy Jul 16, 2026
Capnkev
C
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
