Push rod adjustment help
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date May 3, 2011
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 3, 2011
  • May 3, 2011
I'm reassembling my 351.Just to make sure?I'm adjusting the push rods,and to make sure i'm correct?You make sure the lifter is all the way down and spin the push rod tighting the rocker till it shows some resistance on the push rod,then tighten it another 1/2 turn???This is on a flat tappet cam lifter..peace
john
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
May 3, 2011
  • May 3, 2011
i'm assuming it's hydrualic flat tappet. if so, you adjust the intake side as soon as the exhaust starts to open, and the exhaust side once the intake opens fully and just starts to close. i would adjust them 1/4 to half turn past zero lash. I twist the push rod and when it just stops spinning freely your a zero lash. i tighten the nut 1/4 turn, sinch down the lock on the poly lock and then tighten the nut another 1/4 turn.
Hope this helps.
S351Saleen77
423
Washington
May 5, 2011
  • May 5, 2011
john
Hey John,
Yes thats how you do it. Some go more but I have always used 1/2 and never had a problem.
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
