Push to start wiring?
  • Thread starter Thread starter KAILUAZ
  • Start date Start date Jul 17, 2007
KAILUAZ
333
St Pete, FL via Kailua, HI
Jul 17, 2007
  • Jul 17, 2007
Anyone know how to wire an ignition setup like this? Its for a 86. This is for a race car and I don't necessarily need the keyed ignition.
93 LX
3,081
Norwalk, CA.
Jul 17, 2007
  • Jul 17, 2007
no you cant because you have a mechanical ignition switch located in the stering column. If you re-wire the column then you can take those wires which start the car to some switches through some sort of a relay it would work.
Good luck and if you attempt this better have a wiring diagram.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Jul 17, 2007
  • Jul 17, 2007
If anyone can provide a schematic, that'd rule, because we need to UN-do the push-button start some fool rigged up on Frankenstang's '86 'vert. You still have to put the key in and turn it forward to the run position, but the push-button is what engages the starter.
I'd imagine all it really would entail would be doing something similar - rigging a bypass momentary switch that activates your starter - and then finding a way to rig the ignition to be switched on/off from the run position without a key. You could always just do away with the lock/tumbler altogether and just reach under the column (with the shroud off) and manually move the ignition switch forward/back, but it would look horribly ghetto. And besides ... do you WANT your car to be stolen, or something? Having a functional key/tumbler would seem liek the first line of defense against thieves, to me...
FrankenStang
Now, give me a damn CT!
4,461
70
129
Florence, Az
Jul 17, 2007
  • Jul 17, 2007
cjones
1,561
Avondale, AZ
Jul 17, 2007
  • Jul 17, 2007
do you still want to turn the key for everything else??
KAILUAZ
333
Jul 17, 2007
  • Jul 17, 2007
If someone really wants the car they are going to get it no matter what. I plan on using a hidden switch to deter theft,,, thanks,, I just need the wiring info.
cjones
1,561
Avondale, AZ
Jul 17, 2007
  • Jul 17, 2007
Frankenstang and KAILUAZ , here's the diagram
  • 1986 GT Start-Ignition diagram.pdf
KAILUAZ
333
Jul 17, 2007
  • Jul 17, 2007
I was thinking of using two switches for the run and acc in the same manner. Just flip all three and hit the button and go.
Thanks for the PDF!
cjones
1,561
Avondale, AZ
Jul 17, 2007
  • Jul 17, 2007
Thanks for the PDF!
since it's for a race car,
if you aren't running a computer or A/C. do you need lights??
i'd rewire it from scratch. painless wiring has harnesses to get you going. that way you get rid of all the excess wiring.
KAILUAZ
333
Jul 17, 2007
#10
  • Jul 17, 2007
  • #10
Yeah I need lights and wipers. It couldn't of been that easy hahaha
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Jul 17, 2007
#11
  • Jul 17, 2007
  • #11
Awesome diagram! Thanks.
FrankenStang
4,461
70
129
Florence, Az
Jul 17, 2007
#12
  • Jul 17, 2007
  • #12
OMG,
No, seriously...
Distortion 5.0
114
#13
  • Jul 18, 2007
  • #13
I did my own once, but I didn't use any relays.
The result?
Well it worked, but was accompanied by occasional smoking.
My advice, be careful.
KAILUAZ
333
Aug 27, 2007
#14
  • Aug 27, 2007
  • #14
Anyone else?
K
kickascii
241
Inwood,WV
Aug 27, 2007
#15
  • Aug 27, 2007
  • #15
I've got a Painless Wiring kit 50210 that I use for Water Pump, Fuel Pump, Cooling Fan. However, I just put my engine back in and the key is not cranking the starter so I'm tempted to use the momentary switch for my ignition switch. I'd still have to turn the key on, but this would be simply taking a 12v source to the switch and sending it to the starter solenoid when the switch is on, right? How many amps is that going to pull? It's doesn't pull much, right?
I'm not sure why it's not cranking now. If I short the starter solenoid, it cranks.
Any help?
Anyways, this kit might work for the original post on this thread. Here is a link:
http://www.painlessperformance.com/webcatalog/largeview.php?SearchField=50210
K
kickascii
241
Inwood,WV
Aug 28, 2007
#16
  • Aug 28, 2007
  • #16
anyone?
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
  • Mindseye007
  • Aug 16, 2026
Mindseye007
