Hey guys,
I just switched up my valvetrain on my build with the following items:
-Anderson N-412 cam
-AFR 185s w/ upgraded springs
-Scorpion 1.6s
-ARP Rocker Studs
-Trick Flow 6.035 hardened push rods
-Ford Racing Hydraulic Lifters
And some extras to help out:
-CompCam push rod length checker tool
-Test Hydraulic Lifter with washers in place of spring.
The hardened push rods were left over from another build. The stockers are 6.027 so these are a tad longer. I originally used the checker tool on my previous setup to get my 6.035" length (those were on 1.7s with GT40s though), but after trying both the stock 6.027s and the 6.035s on this setup, they both *look* fine. The marker trick doesn't seem to work so good on these Scorpion rockers, I can't get it to smudge any markings to compare the two lengths. Does anyone have any other tricks for marking the valve tips? Should I put some tape on the roller side of the rocker to help it make a mark? (i just thought of that now..)
I have provided some photos of the 6.036". Sorry they are a little blurry, it was from my phone. Like I said, they look good, they roll right down the middle, it rotates nice, no hesitation (i know i am well within tolerance of the springs with this cam), but I want to have total confirmation.
Thanks!
Valve Opened
Valve Closed
Valve Opened.. i think
-Anderson N-412 cam
-Scorpion 1.6s
-ARP Rocker Studs
Thanks!
Valve Opened
Valve Closed
